1 - 7 of 7 Posts
Friday night pulls at Francis Creek WI.
Well we had everything loaded and ready to go on Thursday for the pulls this weekend, Told Daddy I’d pick him up at 3:00 p.m. to head down to Francis Creek on Friday night.
As I pulled up to his house to pick him up I found my Mom out front waiting for me with camera in hand. Seems she wanted to get a few photos of Daddy and me before we headed out of town for the pulls. Which was great seeing I tried this at the Oconto Pull but my camera didn’t work.
(Daddies doing OK with the chemo but getting frailer every week)
OK onto the pulls
The Pulls start at 6:00 so I figured leave home at 3:00 p.m. with a 1 ½ hour drive there gets us there at 4:30 early enough to get a good parking spot with this 65’ rig. Well to my surprise everyone is getting there early now to beat me there. We pulled in and the lot was ¾ full already. Oh well I still got a really good place to park at the end of the track so we could use the trailer at a platform with lawn chairs set up. Had about 15 people they’re sitting in comfort above the heads of those standing next to the fence.
With the STPA Club I run two classes 5700 Super Stock and 6250 Super Stock, So All I have to do is throw weights around with this club virus Changing Tires with the other clubs I pull with.
So I pull all but 100# of weights out of the weight box to make the light class weight.
OK At the drivers meeting their always are looking for Flag and Hook people to help out during the pulls so I volunteer to flag until my first class lines up.
So the pull starts with the light Open Stock class and even thou they watered the track during the week it was dusty as all heck. So after the open stock class was done they put just a little more water on the track to hold down the dust, well they where using the local fire truck and needless to say to try and sprinkle just a little water with a 1 ½ “ fire Hose is not easy. So they had about ½” of slime on the track now. So as been the flag guy I took over the Track Boss position and got the guys on the tractors and skid steer to work the track over dragging it back and forth the try to get the clay to a more even sticky type of track condition. 20 minutes later it was better but not perfect but I knew as the trucks worked it up it would come around.
So Up next was the Street Stock Trucks class (This is my Daddies class)
As the class starts the first two trucks had a ruff time moving the sled, lucky for the first guy cuz he got the 1st puller go around, but the guy in the 2nd spot got the bone cuz he had it in High range low and could barely spin the tires. But that’s one of those learning things. 3rd truck out was Tony Kuzub when he left the line I knew I was standing in the wrong spot on the track and he had me back peddling pretty good to stay in front of his truck as he pulled it to the 270’ mark. Now I knew the track was getting better and as each truck pulled you could see the grip was starting to form in the clay surface. Daddy luck out and got the number 8 pulling spot out of 11-truck class. And when his turn came up the top truck was at the 295’8” mark. Well Francis Creek has always been kind of like my daddies track, his always done good here, and tonight was no different. Daddy rolled it out about 5’ and then matted the gas and you could see the truck just stand up on all four’s and hauled a$$, there was nothing going to stop him tonight. I had to holler at him to stop at the 330’ mark where he was still going at a pretty good clip. He said to me he wanted to keep going till he hit Green Bay WI. But as he back up to get unhooked from the sled I heard he had a miss and I thought I heard a Klacky rocker, which meant he broke something in the valve train. Well as it turned out 4 other trucks made it out the end, but daddy was going the fastest of all of them when he pulled. And seeing he broke something I scratched him from the pull off and he finished 5th for the day.
So now the tracks really coming into it’s own now, as the trucks pulled they where putting very little clay in front of the pan, so the track crew had very little to fix after each pull.
So finally the Light S.S. class was up. I was the 2nd puller Which really sucks ….. Unless they goof and have to reset the sled, which they did and that made me the 1st puller after the reset. (Alright then here’s the game plan Haul it out the end try not to over spin the motor and keep the tires hooked to the track Easy enough right) …….
Well as I rolled it out of the hole I put the peddle to the metal at the 50’ mark and ShaZam Zinged up to 8200 Rpm’s so I got out of the gas just enough to let the tires get a good hold of the track and then matted it again as I hit the 200’ mark I was gaining speed and I felt the weight box hit the top of the sled my tach sat at 7400 Rpm’s and was hovering between 74 and 7600 till I walked out the end at 315’. Opps I said to myself that was too easy there going to reset the sled again. So I headed back to the pits and I regeared the truck to help lose the 500 extra Rpm’s I had in the first pull.
So when the last truck in the class pulled to the line I fired up ShaZam and took her back to the staging area. But to much of my surprise they said they didn’t reset the sled and my Full pull was 1st place for the light class.. YA hoo …… End results 32.6 MPH wheel speed 1st place
So it was back to my pit area to add all the weights back to the weight box and regear for the next class.
In 6250# Super Stock I was the 8th puller out of 11 trucks and they had the sled set right from the get go, most trucks where pulling it to the 290 to 295 mark then the first full pull came from the Kakuk boys then Bill Dane was out and two other trucks pulled 295’ and 298’ and then it was my turn to hook to the sled.
As I watched the trucks that pulling in front of me I could see there trucks seem to be bouncing in the rear ends a lot going down the track and the end results where it was getting a washboard effect in the ruts they where leaving. So when I backed up to the sled I staggered the ruts by a tire width to get to good smooth clay for my run. And it help me a lot, I was smooth and it was a replay of my first run in the light class only this time I didn’t over spin the motor Tires hooked to the track I turned 7400 Rmps for pretty much the whole run and walked it out the end with ease. With end wheel speed 33.75 Mph. So stop for some fuel and back for a pull off with the other trucks. Jack Peters was the last truck in the class and he also yank it out the end. So there’s 3 Ford and One Chevy in the pull off.
I stood and watched as they reset the sled for the pull off and then watched the first two trucks pull and they set the sled tight. But that’s just how this sled is either it’s 300’ + or 199’ .. the first truck to pull was the Kakuk boys and there truck did the rearend bounce again and stopped them at the 190 mark, Bill pulled up to the line and pretty much did a 6000 R dump the clutch run and pulled it to 185 mark. Then I did it just like I did the first time staggered the ruts eased it out the first 10 feet then Spanked it like a new born. When I hit the 200 foot mark I felt the weight box hit the top and then it was like I had this big surge of momentum the tach was reading 7500 Rpm’s the tires where hooked and the next thing I knew I was sitting at the 299’ with the biggest smile I had in a long time on my face. Oh Ya ShaZam did really good tonight. So I got unhooked from the sled and headed back to the pits to let her cool off before putting her on the trailer for the ride home. Just as I shut ShaZam off someone ran up to me and said they had a sled malfunction and I had to repull my pull off.
I said what the hell you mean a sled malfunction.
So When I tried to fire up ShaZam she wasn’t cooperating She’d spin over but she was too hot and was kicking back on the starter every time I hit the Run switch. But she finally fired up and I took it back to the staging area.
Where I was told that the 3” lug 5’ long logging chain that they throw under the pan to help slow us down in the pull off came undone during my pull and that’s where I got my bust of speed from when it came unhooked. OK makes since to me, but boy I sure wish it hadn’t done that.
OK So Jack was hooked to the sled and made a really nice 220’ pull but he went somewhat to the right of where everyone else pulled. I left my water pump and fans running during his pull hoping to get ShaZam cooled off some but when I fired her up the water temp. was still 180* I needed more time to cool off. And By rights I should have demanded the time seeing there was the Malfunction and all. But I pulled on to the track and like I did twice before I staggered the ruts to the left and as I was leaving the line ShaZam slid into the ruts and as I hit the go fast peddle ShaZam just erupted the tires and zinged to 8200 Rpm’s and I couldn’t get no traction at all. Ended up pulling 175’ and finished 4th for the night. Man this sucks 1st to 4th .. End results 8200 Rpms 37 Mph = going nowhere .
On the ride home I replayed that final run in my head 1000 times. Next time I’ll take my time and do it right. I lost control of everything on that run, I now know ShaZam didn’t let me down I let ShaZam down.
SO OK there another pull there tonight We’ll be leaving at 3:00 again , hope Daddies truck stay together tonight and I’ll try to make it up to ShaZam tonight.
Dan
Dan,I like drag racing but your truck pulling stories are
always great reading.Keep on posting them as i always like reading them.
Later Mark.
Great night Dan. :wink:
I don't know much about the set up for you pulling guys, so what are you referring to when you say regear between classes?
Well David : I have a profab transfer case in my truck and I have 20 sets of Gears for it from 400 to 2000 so I'm able to change my gearing in about 2 minutes. it's like being able to change you rear end gears in your race car from 3.50 to 6.20 in 2 minutes with only getting some gear lube on your hands .
I can go from a 28 to 1 final ratio to 15.5 to 1 final ..
Dan
Dan
Thanks for the explanation Dan.
1 - 7 of 7 Posts
