i have a 1979 bronco that i just swapped a 460 into with the 2wd trans that i rebuilt to 4wd with a 79 f150 output shaft and adapter i have an np205t-case that originally came off my t-18 manual transmission. My problem is my front driveshaft double cardan joint hits my transmission where the pan meets the case is there another adapter for this transmission or can i cut some material off the transmission and pan to clear it
