1 - 11 of 11 Posts
.....so I go to the track on Sat. conditions were absolutely terrible!!
22 MPH head winds, blowing sand all over the place (this is at LACR, in the hi desert, north of Los Angeles), slippery track, etc.
I could'nt get my car to run anywhere near what it "should" be running.
Of course I took the track condition into consideration, but still, I've ran much faster before with the same kind of crappy conditions.
Heres how things went.
First run, I do a moderate burnout and stage. Ran a 13.42....Im like WTF?? :evil:
Check timing, its only at 28 degrees LOL!! re-set it to 36.
2nd run...12.42, much better, but still, this POS should run easy 11.50's to 11.60's.
3rd run...12.77 now Im pissed because its getting slower.
4th run...13.03 :roll: ....now I simply look like a dumbass!!
Check the plugs, they are white as a ghost!! pull the jets to check what size they are (carb is a Holley HP 1050 Dominator), they are 82/84.....so I step it up to 87/89's
5th run...12.78.......Im gonna KILL SOMEONE!!!! :evil:
Check the plugs again, there is a little bit of color on there, but not enough.
Where the f*** are my jets at?? I could'nt find them (later found out that I forgot them at home :x ).
Oh well, not much tuning I can do now.
6th run....12.90 spinning badly. Let out some air in the ET Streets, down to 15 psi.
7th run...12.66. Screw it!! Im putting it back on the trailer.
This was the first outing with this new combo. Its not much of a "radical" combo, but still it should be much faster/quicker than this.
Heres a quick rundown of my combo...\/
Car: 1968 Torino GT....4000lbs (with me in it)
472 cu. in.
11.5:1 CR.
Edelbrock aluminum heads...large CJ port version. They are ported/polished.
Victor intake man.
1050 Dominator
Comp Cams solid flat tappet cam 260/270 @ .050" 106LC .640"/.666" after the lash, its .628"/.652"
2" inch primary headers into 3.5" collectors, full exhaust with Flowmaster 2 chamber muffs.
C6 trans with 3200 10"inch convertor ( I think I'll try a 4500 convertor)
M/T ET Street tires 28x12.5"
I know I need to fiddle with the jetting, and I feel that my convertor is holding me back big time.
Should I try open headers??
60 ft. & MPH:
1st run....2.084/108.3
2nd run....1.897/108.35
3rd run....1.991/108.32
4th run....2.104/108.288
5th run....1.990/108.659
6th run....2.018/107.601
7th run....1.992/108.364
Right now, its all over the map....I gotta jump in with both feet on this turd!!
It aint gonna run much better than a 12.42.....with those 108mph trap speeds.....those 60ft times are not too good...coming out of the hole that slow with that cam and that weight, its not gonna get wound up too fast..loosening the lash should build some lower rpm torque....looks as though you do have some issues there....what gear are ya running?....if the plugs look that lean what kind of fuel system are you running? is it running out of fuel?.........good luck....D
Gears are 4.33's, the fuel system consists of a Holley "black" pump with 1/2" inch line from tank sump to carb.
I have a steady amount of fuel pressure all throughout the runs, it stays at 7 psi always.
The exhaust is 3" inch with FlowMasters.
Funny thing is, I had a "lesser" combo running 11.70's last year.
The trans is built, it has never failed on me, but it may be getting tired. I've noticed that the shifts are not as crisp as they were 10 years ago!! :roll: ..... :D
The carb dont have any power valves, its the "power enrichment circuit delete" model.
Strange, mine came right out of the box with 86's front and rear. Unfortunately, I lost the jets!! :oops:
I run 92's square in my 1050. Also, your thought about trying open headers will probably improve things quite a bit. I use Flowmasters to keep the loose papers from blowing out of my trash can on windy days. :lol:
1 - 11 of 11 Posts
