Ford 460 out of a 1975 Lincoln Mark IV $350 O.B.O. - Pickup only in San Diego
Block is 2 bolt main and has been magnafluxed, Mains are line honed ten thousands over and cylinders have been rough bored to 20 thousands over and are ready to be matched to whatever pistons you want. Crank has been magnafluxed and turned ten thousands over. Rods are from Performance Automotive Warehouse they are Ford OEM "DOVE" rods that have been reworked and balanced. I also have ARP high tensile strength Rod bolts. There is over $350 in machine work alone, all machine work was done by Ed Hale motors in El Cajon, CA. - Also included but not pictured ar the original Rods and the heads which need to be worked on.
