1 - 20 of 32 Posts
All completely brand new never run
iron d9te-ab block 4.39 bore 2-bolt main
forged probe SRS pistons with moly rings 22 cc dish 4.39 bore
4340 forged crank and h-beam rods 4.3 stroke 6.8 rods arp rod bolts all professionally balanced
touched up trick flow streets 429/460 dual valve springs with damper, titanium locks, .270 raised exaust port, 2.2/1.760 in/ex valves forged pushrods, scorpion performance 1.73 rocker arms fastened down with ARP 12 pt. bolts
comp cams custom grind # ff 3357/3358r, gross lift- .577/.586 in/ex duration- 248/254 in/ex @ .050 lsa- 112 (cam spec sheet included) assembled with comp cams hydraulic lifter set
ALL completely assembled by Coast High Performance in Torrance Ca. aka Probe Racing Components all paperwork included
ALSO included:
trick flow fabricated valve covers with gaskets
ARP engine hardware kit chrome 12 pt. (pretty much all bolts needed to fasten timing cover motor mount bolts etc.)
milodon gold iriated rear sump oil pan 7 qt. with milodon oil pan stud kit and one piece gasket perfect for a fox chassis
CSR valve cover breather restraints with mr. gasket breathers
summit racing front timing chain cover and gaskets
Guys im in quite a pinch here as i just lost my daily driver thanks to those who cant drive and this engine will NOT be a good daily driver even though it would be really fun :) im asking 6000 for everything since i payed over 8400 for all of it (have paperwork to prove) and am willing to ship i am located in yorba linda, california please pm me if interested
CC on the heads? Who did the heads and installed?
Compression ratio?
You don't say, but is it a flat tappet or roller hydraulic cam?
What did they rate the HP/TQ at with appropriate intake/carb?
Thanks!
c.r. is 11.7 to one
hydraulic roller
heads are 290 cc runners intake and 130 ex. with 74 cc com. chambers and theres no intake manifold so who knows what you can make i say you could pull 700 n/a out of it
and coast high performance installed the heads and did all work
Discussion Starter #13
it doesnt come with a intake manifold or carb but this motor is set up to handle a good 6-700 maybe more ive seen similar combos with 750+ reliable n/a hp with say a victor 460 mani and a dominater carb up top or you can even just go fuel injected (thats what i was gonna do) this is a superb price for everything listed
1 - 20 of 32 Posts
