1974 F-100 - Long bed, regular A/C cab, P/S, A/T
Fresh motor within the last year -
Short block - New 0.030 cast pistons, moly-rings, align-honed, square decked, honed with deck plates, 0.010/0.010 crank, balanced rotating assembly
Heads - Hard seats, valve guides, valves, spring height set, surfaced deck and exhaust flange.
Valve train, induction, ignition, exhaust - Comp 268, adjustable rockers, Edelbrock Streetmaster intake, 600 vacuum secondary, Hooker headers, Hooker Maximum Flow Mufflers, Duraspark distributor, Crane Hi-6 box
Interior - new door panels
Suspension / brakes - front brake hoses, I-beam pivot bushings and radius arm bushings. Rest of components look fairly new
Misc new parts - 3 row aluminum radiator, water pump, starter, rebuilt P/S pump, steering rag joint, harmonic balancer, flexplate, belts, hoses
More pix here
http://s87.photobucket.com/albums/k132/FE_rex/74 F-100/?start=all
$4900 :1-hr west of Houston, TX
