1 - 3 of 3 Posts
Bought these for a motor I was going to build but found a freshly machined block for cheaper than machining my block to fit these ended up at 0.060 over. My loss your gain. Brand new in box, also including a new set of mahle cast rings.
SPECIFICATIONS
Silv-O-Lite 1143HC-040 .040 Over Hypereutectic Pistons
Skirt Coating: Yes
Bore Size: 4.400
Piston Style: Dish with 2 valve reliefs
Piston Recess: Oblong recessed piston design is 0.230 in. deep
Compression Distance: 1.76 in.
Dome Volume cc: -021.0
Wrist Pin Style: Press-fit
Pin Diameter: 1.0402 in.
Pin Offset: .06"
Piston Ring Thickness: 5/64 in. x 5/64 in. x 3/16 in.
Quantity: Sold as a set of 8
OEM Assy. Number: C8VY6108A-B, D2VY6108A-B, D3VY6108A-B
Note: The coating on one of the pistons has a small scratch as show in the last photo.
Note: Non EFI vehicle
135/best offer + shipping for the rings and pistons.
WILL TRADE FOR ROLLER ROCKERS, WIEAND 8021 MANIFOLD OR C6 SHIFTER.
1 - 3 of 3 Posts
