I have been out of work for awhile and decided to take a different direction with my coupe for now. I have over $12,000 invested and everything is still new in the box. I’m asking $8,000 OBO or I will trade for a modified pump gas SBF + cash. I can email piston spec’s, cam spec’s and sonic sheet as requested. Since I am not working I can also deliver just about anywhere for travel costs. I don't want to part it out at this time.
1971 CJ DOVE-A block bored .080 to 4.440". Honed for moly rings. It’s been parallel decked and cut for O-rings. O-rings have been installed. Main saddle has been honed true to cylinder bores. Lowest point on any non thrust flange is .178" before the bore job which leaves .138". 4-bolt mains, new ARP studs included for the heads and mains. Half fill of blocrete.
Summit Racing:
Trick Flow A460 heads TFS-5440T802
Trick Flow rocker stud girdle TFS-54400700
Trick Flow roller rocker arms TFS-53400621
Trick Flow tunnel ram top gasket (extra) TFS-54494140-G
Trick Flow black valve covers TFS-53411802
Trick Flow A460 tunnel ram TFS-54494000
Trick Flow A460 tunnel ram top cover TFS-54494140
Isky Red-Zone roller rockers ISK-3172-RH
Holley 4500 dominator carburetors (2 EA) HLY-0-9375-1
Summit timing chain cover SES-5-80-04-201
ARP stainless 12-point intake bolt kit ARP-455-2101
ARP cam bolt ARP-255-1001
ARP 12-point distributor stud kit ARP-450-1701
ARP balancer bolt kit ARP-150-2501
Milodon gear drive assembly MIL-14600
AD Performance:
Custom forged JE pistons approx 14:4.1
Scat forged h-beam rods
Scat forged crank
Perfect circle rings
Pioneer harmonic balancer
JW flex plate for powerglide
Balanced rotating assembly
Other:
Custom comp cam by Lem Evans
Motofeet engine stand
Thanks,
-Allen
214 770-6669
$8,000 OBO or trade for pump-gas SBF + cash
