Trying to find this blade type coupler retaining clip. Goes inside coupling to the larger (3/8"?) stem on fuel pump. Finger style clips won't work, need help or part # or viable option. Thanks -
Automotive lighting Automotive design Automotive tire Automotive exterior Output device
Discussion Starter · #3 · (Edited)
I came to the forum because no parts store has anything like them, nor any listings in their books. Same with dealerships. Hoping someone in the forum might know of a shop stash of the old school stuff. They're apparently unique to the dual tank trucks because the coupling is a check valve as well. Starting to look like only choice is salvage yards or cutting tabs on the fingers style and taking a shot with them.
Knowing Ford, that's something that you can only get as a part of a hose assembly... Make nice with the parts guru at your local Ford dealership and explain what you have going on.. In person helps out a lot better than just calling sometimes..
