Replacing both the feed and return lines on my 90LX with -6 lines and I've got a question. I'm using push-lock hose from front to back, gnna be careful to route it as specified to the rule books and a safely as I can (no it's not a racer, just a street car that may see a pass or two). Question is, will I be up to spec using push-lock hose front to back and back again or do I have to use braided or hard line? Thank you for your advice and consideration..
For an 11 or 12 second car I don’t believe any tech inspector is gonna give you a hard time if you use a push lock hose.
Now if you run into a tech inspector the day after he finds out that his wife is banging the neighbor you may have a different outcome 😂
