I just picked up a Zex dominator 100-300hp kit for my 545 project, what I want to know is will my Aeromotive A1000 pump with the 13204 2port bypass reg be able to feed both the carb (1150 holley) and the nitrous? I have -10 lines all the way from the tank to the reg, and then -8 to the carb. I want to run a -4 line from the other port on the reg to the nitrous. I have read on different posts that two separate regs must be used as the carb and nitrous can need different psi settings, I know that the nitrous needs 6psi, will the psi setting for the carb only be known at the tuning stage? Or will 6 be fine for both?
