1 - 7 of 7 Posts
Does any one know if a big truck oil pan was full sump for the 385 like this F-600 oil pan that i used on my FE. thanks .Ron
i have a big truck pan but its like a mid sump.
I have an oil pan from a f 600 or f700 that had a 385 series motor in it, its a rear sump. The pan is much deeper in the front and back than the regular light duty truck pans.
Hookedonpullin,
Does the pan you have have the sump all the way to the rear like the FE pan in the picture? I am looking for a factory pan that has a rear sump all the way at the back like a fox body pan, so that i can modify it for my draglink to run through it and still have a little sump to put my pick up at the rear.thanks.....Ron
The ford pan I have on mine had the following part number(s) stamped on it: (#4 0489A) E7HE 6675. This is the best pic I have to show it's shape, holds about 10 liters.
found this one also:
Danny,77f-150,thats exactly what i was looking for ,thanks guys.
77f150 is that the stock pan for your truck?I may look for a good used one , i still have to modify it to put it on the mustang. Or i might save the hassel and just get a new one then modify . thanks again........Ron
1 - 7 of 7 Posts
