1 - 20 of 29 Posts
E7TE EFI castings.
Fully rebuilt with bronze guide liners
P/C seals
Pedestals converted to studs and guideplates
Upgraded intake valve from 2" to 2.083" / exh is 1.65" both are S/S
Decked .025"
Single with damper performance spring package 110 / 280.
Studs and 5/16" guideplates included.
Intake entry gasket matched and fully ported
Exhaust fully ported
These castings will be ideal for a towing combo requiring high torque.
Cost for ready to bolt on castings is $1095.00
Also available is a ported EFI OEM intake which has been reworked at the runner exits significantly increasing flow capability.
The intake is $200.00 EXCHANGE only.
Thank you for looking.
RHP will also supply tips for maximising your fuelie combo with parts choices that will work with the stock ecm.
8)
I will be getting back to you on this being it is almost time to start work on my '91 F250 7.5L EFI Truck.
Thank you
Thank you
Noted.
Thanks for looking...
8)
TTT
Bump.
8)
TTT
ttt
TTT
bump.
8)
TTT
Bump
8)
InfoFord said:
okay I am building a EFI 545 for towing if I can almost steal these heads and matched intake I might be interested
what is your absolute lowest dollar you will take for this setup
PM me with a reasonable offer.
8)
TTT
Bump
8)
TTT
bump.
8)
Discussion Starter #12
TTT
n/m
8)
Discussion Starter #13
TTT
Bump...
8)
Discussion Starter #14
TTT
Bump and $100.00 off.
8)
Discussion Starter #15
ttt
Shameless bump...
8)
Maybe a stupid question, but....
Are these steel or aluminum?
Complete? so, including rockers etc.?
What's the weight of the heads?
What's the CC's of the chambers?
Thnx.
Discussion Starter #17
Thnx.
These castings are the truck only fuel injection castings. They are iron, have a 96 cc chamber volume and require unique intake and exhaust manifolding. They are complete less roller rocker arms.
8)
Ok.
I have the D3TE casting's now..
They are complete reworked (valvejob, springs, etc.)
Do i gain much? (enough to justify the amount for the 7's, and throw my 3's in a corner..)?
Engine is completely redone, and has KB/Silvolite KB137's in them. I thought CR would be around 9.0:1 (i hoped for more, as i intend to ride on LPG..)
Then again, as they need to be shipped, what's the weight of the heads?
thanks.
Discussion Starter #19
Ok.
thanks.
Just for clarifications sake. You currently have an EFI type engine converted to propane? F3TE fuelie castings???
The castings weigh about 70 pounds each.
8)
Yes, i have a fully rebuilt '92 EFI truck engine, which i want to install in my '79 Towncar. It has everything new/remanufactured, and a RV cam in it which is acceptable by the speed-density system.
My Lincoln Towncar run's on LPG with an impco 425, and i want to take the elbow off, and put the 425 with a throttleplate and a EFI adapter on the engine.
When eveything brings a big smile on my face, i will try to go the Megasquirt route and connect the injector's, sensor's, and a MAF conversion-kit.
When THAT all works, it's a fair easy step to LPG injection :)
I know, idea's, plan's, etc. :D :D
Weight of the heads: 70 pounds? :shock: :shock: :shock: :shock:
Is that int'l shippable???? :?
1 - 20 of 29 Posts
