Manley titainum exhaust valves, (8) very good used, 11/32" stem, 1.90 tulip head, .350 tip, 5.66 long. $400.00
Comp. pushrods, good used. (1) pc. 3/8", .080 wall, (8) 9.75, (8) 9.35. $40.00
Edelbrock carb, #1404-1922, 500 cfm. (4150 sq. bore), used $55.00
(1) crank dampner spacer, new in package, #M-6359-C460 (short blk. anodized pc.) $25.00
K-Motion titainum retainers, (16) used, fit K-Motion #K-1000H springs. $50.00
Boss 429 tunnel ram, Weiand, show polished, ported and flowed, (2) tops dual 4500 and 4150. $650.00
MARINE PARTS
BBF Owens bell housing, very good used, drilled and tapped for Owens clutch and/or 2 speed, bottom is clearanced for shaft log / prop shaft, billet motor plate supports. $225.00
BBF rear motor plate, "V" drive, fit 26" wide stringers, starter pocket for 164 tooth flywheel or flex plate. (will work with Owens bell housing), 3/8" natural aluminum finish. used. $200.00
BBF rear motor plate, "V" drive, fit 26" wide stringers, with light wt. fabricated flywheel cover, all tig welded, billet adapter for 5" diameter drive line cover, starter pocket for 164 tooth flywheel or flexplate, 3/8" natural aluminum finish, used $400.00
BBF (2) front motor plates, "V" drive, fit 26" wide stringers, fabricated to accomodate a Danny Bee belt drive, 1/2" natural aluminum finish, used $200.00 ea.
BBF 1350 P.T.O. with bolts, used $35.00
BBF custom made race headers, fit A/460/TFS heads, stepped 2-3/8" to 2-1/2", short 4" collectors w/ cone transitions, all tig welded, new Jet Hot Coated. $650.00
Boss 429 headers, customized Bassetts, shortened 2-1/4" primarys, 4-1/2" collectors, plugged water injectors, Jet Hot Coated. $250.00
Shipping is extra, Joe Sr. 707-864-0332 California
