1 - 20 of 41 Posts
AR tunnel ram manifold, magnesium, dual 4500 top, 1" abs spacer, s/s bolts, fits AR-441 hemi heads, 10.300 deck. Rare item. $1500.00 (custom throttle linkage is not included)
Crower roller lifters, custom made for C&C, .903, z-bar, for Boss 429. #66299H. Has hi-pressure pin oiling. New in box. $500.00
BME 426 aluminum rods, (2) sets of (8), 6.800 x 2.200 x .990. BBF on center design, Very good used. each set has 100 easy passes. $350.00 ea. set or $600.00 for both.
(8) Manley titanium exhaust valves. 1.90 tulip heads, 11/32" stems, 5.66" long, .350 tip. Very good used. $375.00
(1) Mr. Gasket intake gaskets #207, (original Boss 429 heads), new in package. $24.00
ATI flex plate, 164 tooth, includes spacer. Very good used. $155.00
Moroso coil #72381, CD type, 40,000 volt. Only (5) passes. $60.00
Crane rocker arm nuts. (16) new, $12.00
Crank dampner spacer, Motorsport #M-6359-C460, new in package, aluminum. $15.00
(8) Arias piston pins, taper, .990 x 3.125, 180 grams, very good used. $35.00
Boss 429 pushrods, (8) new exhaust, cup and ball, 3/8", 10.500" long. $55.00
Boss 429 pushrods, (8) used intake, cup and ball. 3/8", 8.625" long. $30.00
Boss 429 pushrods, (5) used exhaust, cup and ball, 3/8", 10.625" long.$15.00
Boss 429 pushrods, 3/8" x .080 wall, (1) piece ball and ball, (8) intake, 8.325" , (8) exhaust, 10.800, Very good used $80.00
Shipping is extra, located in California. 707-864-0332 Ask for Joe Sr. ( I will e-mail additional pics.)
Looks good, I'll take it if the first in line doesn't want it. I see your in the 707 area code, I may just come pick it up depending on how far toward the coast you are.
Its yours if you want it. Our shop is in Cordelia. Precision Craft Marine
9320 W. Cordelia Rd. Suite "B"
Fairfield, Ca. 94534
707-864-0332 (Tue-Sat.)
Thanks, Joe Sr.
1 - 20 of 41 Posts
