1 - 13 of 13 Posts
1. AR magnesium tunnel ram. For a 10.300 deck and fit AR-A441 heads. Has a 1" thick abs spacer, s/s bolts. Very nice condition. $1500.00 firm
2. Tilton severe duty starter, very good condition, clearanced for for pan and 164 tooth flywheel. $225.00
3. Comp Cam new, 289 in. duration, 485 lobe lift. 292 ex. duration, .500 lobe lift. 114 lobe seperation. $190.00
4. Bullet Cam (I think). new. 286 in. duation, 470 lobe lift. 303 ex. duration, .517 lobe lift. 115 lobe seperation. $190.00
5. Moroso coil, CD type, 40,000 volts, very nice only 5 passes. $50.00
6. Manley titainium exhaust valves, (8) used, 1.900 x11/32 stem x 5.56 long, .350 tip. $275.00
7. Wilson nitrous plates, dual dominators, #302316 with burst panels. Capable of 250 hp ea. Nitrous solenoid #372257 w/ purge port, solenoid capable of 700 hp, Fuel solenoid #371312, capable of 700 hp.
(5) jet sets for 100 to 300 hp. Includes extra burst panels. Purchase new for over $1100.00, bolted on but never used. $700.00 shipped to the lower 48.
8. Peterson dry sump pump. 4 stage with bear claw mount,(allows you to mount to a plate or bracket in place of your choice on the left side). It has (3) #12 scavenge fittings, #16 to tank, #16 pressure in, #12 pressure out. Pump is in excellent shape. $500.00 shipped to the lower 48.
Will e-mail pics to those interested, Call for more info 707-864-0332 ask for Joe Sr.
1 - 13 of 13 Posts
