1 - 20 of 23 Posts
7 sealed power .030 over cast pistons with rods $50.00 (can still get one more to make a set)
1 set of 8 factory rods with bolts and caps. $obo
2 stock timing sets $ obo
1 double roller timing set $15.00
1 stock 429 crank ready to be polished $25.00
1 set of king rod and main bearings for .020 under on rods and mains (new in the box) $50.00
...everything is located in lakeland, fl
thanks
james
location is fixed...headers are a fender dump set. i had them in a ford ranger but would probaly fit many trucks. they come off the heads about 12" before the first turn, if that helps any.
james
1 pair of tall ford motor sport valve covers, need polishing $50.00
1 pair of tall polished aluminum valve covers only run twice $50.00
pics t. if they are I will take 1 of the 2 pair
pm sent
Kjett sent me over here :D
Got any pics of the water pumps? If they're in new-ish shape I'll give you 20 for both shipped to 21085.
got it kjett and responded...
captain thanks but the ride would cost almost or more than 20...thanks though
got yours and responded back.
Paul, quint being cheap and pay the actual shipping, it'll be cheaper than what you can get one for anyways.
Okay, tell me what you want for it shipped then.
How much if it gets thrown in the box with Karl's? We see each other fairly often, if it saves me some money ship it with his. I'm broke Karl, I need to save whatever I can.
1 set of l&l products 460 swap headers for bronco (i believe) 1-3/4" primary with 3" collector. $140.00
1 set of d3ve heads all stock with a set of edelbrock performer rpm springs & factory rockers $100.00
1 ultradyne solid flat tappet cam...around .650-.660 lift and 110 lobe seperation $75.00
1 brand new in the box lunati hyd cam .600 lift (never seen a motor) $75.00
1 edelbrock street hyd cam .513 lift. not much run time $50.00
1 set of 16 chromoly push rods stock length $15.00
1 set of 16 solid flat tappet lifters $50.00
1 noisy gear drive timing set...poor mans blower sound $30.00
1 Torker II single plane intake 4150 flange $75.00
1 holley 750 carb vacuum secondary used less than 10 hrs $100.00
1 set of 16 trick flow chromoly .080 wall push rods stock length $30.00 -----pending
1 set of 16 hyd tappet lifters $20.00-------pending
1 pair of tall polished aluminum valve covers only run twice $50.00-------pending
james
PM me a price for all this stuff shipped to Leola, PA 17540 and if the pending stuff falls through let me know.
James,
Haven't heard from you in a while. Have you sent the 2 water pumps and FMS valve covers yet? Please send me a tracking number so I can let my wife know when to expect them. I'm out of town (out of country to be honest) for a few weeks, just want all my parts there when I get home.
Thanks,
Karl
1 - 20 of 23 Posts
