1 - 13 of 13 Posts
The Fox swap stuff is a Ford Racing 6 qt pan and the motor mounts are also FMS. Crossmember is standard double hump for any Fox body car.
SOLD!
Discussion Starter #2 (Edited)
Let's try this again.
Kaufman serpentine belt setup. You get the block cylinder head plates, 80's era Fox body alternator(hi amp) with bracket, power steering pump with bracket, air conditioner compressor(system still sealed on the car) with mounts, new marine pump with 2 belts. Everything you need to convert your 460 to single belt setup. 600.00.
Cam Research cam drive. Now make external adjustments for timing. 850.00 new. This one slightly used. 395.00 SHIPPED.
Holley 130 gph mechanical pump. NIB. Never used. 100.00.
Pro Systems Nitrous IV 1000 cfm carb. Like new. All the tricks. New from PS 690.00. This one 550.00. SHIPPED.
Post cont'd.
I will trade and am looking for these parts:
Fox body headers for CJ heads. Prefer 2 1/8" or larger primaries.
A429 heads, TFS street heads or ?
I can do a combination of parts and cash for the right stuff that I need/want.
Thanks,
Frank
615-476-91zerozero
Call or text. Best way to reach me. Thanks.
does the gas tank price with mounting brackets and what ohm sender if any. looking to remove the tank from the cab in my 69 f100. thank you
1 - 13 of 13 Posts
