1 - 10 of 10 Posts
auto meter pro shift light#5340 50.00 auto meter sport comp #3700 0-10000 rpm tach 65.00 auto meter phantom #5821 oil press 25.00 auto meter sport comp water temp 0-280 #3531 45.00 b&m pro ratchet shifter/cable 125.00 msd rpm selector 30.00 two holley blue pumps 35.00 each jaz rad overflow bottle 10.00 universal driveshaft loop 25.00 comp cams vac canister like new 50.00 460 ford motorsport windage tray/with studs 50.00 c6 with a shift kit for bbf 460 300.00 tci 3500 converter 285.00 set of weld drag lights with tires fronts are 15x5 mt sport mans 28x7.50 rears ar 15x8 with 3 1/2 backspace with hoosier quick times tires well used 450.00 ford bolt pattern msd 6al box 110.00 arp main studs new for 460 40.00 arp head studs new 125.00 460 ford also a couple of fuel logs 4150 log 10.00 4500 log 10.00 mallory water temp gauge 10.00 1 inch dominator aluminum spacer w/vac fitting 25.00 also 2 sets of cj rods 100.00 for both sets and a 460 crank needs turned standart 50.00 prices less shipping these are listed for my friend call pete at 313-505-1573 no pay pal all parts are used unless noted
It is hard to read...but im interested in the shift light, and maybe the tach. Can you send pics?
Bradleyrj @ hotmail.com (no spaces)
Brad
I HOPE THIS HELPS
I HOPE I DONT MAKE THE OWNER OF THIS POST MAD
msd 6al box 110.00
4500 log 10.00
also
and
no pay pal
I AM INTEREST IN YOU MAIL GIRDLE W/ STUDS
WILL IT WORK ON A A460 BLOCK
AND
YOUR R.P.M. SLEACTOR SWITCH
WHAT IS ITS LOWEST & HIGHTEST SETTINGS
AND
YOUR FUEL LODGES
PLEASE PM ME
GFPRACING
You do not need a main girdle with an A-460 block. 8)
deerhunter3814 said:
GFPRACING
I DONT HAVE AN A460 BLOCK YET
I WAS JUST ASKING OF OT WOULD FIT
I AM INTERESTED IN IT FOR THE BLOCCK I AM NSEING MOW
BUT I AM LOOKING FOR A A460 BLOOK
AND THOUGHT WHEN I GOT 1
I MAY USE IT
1 - 10 of 10 Posts
