Correct....the side ports eliminate that issue. The top ports should not be much of an issue with a dragrace only engine.use lateral ports not top holes for less or no carbon pluging
Thank you Mark. Direct answer from a piston manufacturer, this board is great.
I noticed them lately because people mentioned them in build specs and a couple in the auction block sections.
Sounds like a nice feature to to have. Low tension when its not needed and max pressure when you do. Is this an option for any of the pistons Probe offers Mark?
Thanks, Dave S.
