Built Manual VB AOD with JW BBF Bellhousing
My intention has always been Drag Week but I'm going to Iraq next year and I just don't see this happening any time soon. I'd have no qualms about putting this behind a reasonably powerful BBF (900-ish HP or below - as that was my plan all along).
Looking to get $1800 and I'm definitely losing money there.
So, details:
Built AOD w/ one piece hardened input shaft, Lentech Strip terminator valve body with transbrake and OD full manual (except the OD is actuated electronically) with fixed line pressure, new planetary gear set (standard AOD), new sun gear, new direct drive drum, upgraded to new style billet servos, trick flow deep pan. Forward/reverse drum has 6 clutches, direct drum will have 8 clutches. All clutches are alto reds. Metal 2-3 accumulator valve to replace plastic one, this will firm up the shifts as it seals better. New "anti-rattle" clip that makes the transition from 2nd to 1st smoother.
Trans is located in Northern Virginia and I'd definitely prefer local pickup and cash-in-hand over shipping.
Currently only pics I have:
Yes it is. I’m currently deployed but will be home for R&R in November. It could also be picked up in Warrenton, VA.
