I have an 89 e350 box truck with a freshly rebuilt engine (460 efi), everything parts wise is brand new, including the wiring harness connectors. Mostly used motorcraft parts and other good brands, I have a persistent issue with the engine running the headers red hot after driving for a few minutes. Timing has been checked and set multiple times, fuel pressure is good, brand new cat and no muffler atm. The only two old parts left are the o2 sensor and the ecu. This truck has given me non stop running issues and 0 check engine codes have come up, light works. I did find a very corroded ground strap on the ecu from the heater box leaking, so possible the ecu is jacked up. I am at a loss other than replacing the ecu and o2 sensor. Both headers glow and it seems to run good fine some days then go back to red hot. I've searched the forums and cant find any solutions that I haven't tried so any help would be greatly appreciated.
