1 - 20 of 25 Posts
I have tried, Simple Green, Acid and Super Clean. But none of them seem to cut the grease and dirt that has built-up on my truck frame over the years. I am ready to start getting my truck clean and wired for the engine install and I want everything spotless.
I am going to try a 2,600psi pressure washer this time. Last time I used a 2,300psi and it was more like using a plain water hose.
Anyone know of some good soap or tricks?
I'd go broke using Brake Cleaner I already buy the stuff by the case!
I mainly wanted to see if anyone had any trick mixtures or something like that. I want to clean everything under the truck before I pull it into the shop.
x2 on the easy off. I have used the Gunk engine cleaner too but your gonna have to scrub it with a brush.
Bill
I use a putty knife first, then go to the local car wash,that way the craps not in my driveway.The hotter the water the better of coarse.
If you have access to a steam pressure washer it will take it off. It still helps to soak the bad places with greased lightning or something simiular.
Dennis
If it's heavy stuff, like in the frame corners around the crossmember, I just pour diesel fuel on it and let it soak while I haul it to the car wash... Then use "their" hot water to blast it off... Worked good on my truck...:)
Doug...:cool:
x2 on the steam pressure washer.
We have one at work that is used to clean machines before rebuilds.
With a turbo nozzle and the heat cranked up all the way it'll clean down to bare metal.
mike
Doug...:cool:
Its funny, the Gunk engine cleaner smells alot like diesel, prolly is!!
Bill
Use a Steam cleaner. Get it good & hot, don't let off the trigger, even if you want to stop cleaning, it shuts down the heater. Something about the heat & pressure that does wonders over a plain old pressure washer.
Discussion Starter #13
Would you believe that not one of the equipment rental compaines around here rent Steam Preassure washers or even pressure washers for that matter!
Good grief, sometimes I think I live in the middle of no where!!
Discussion Starter #16
Ok so maybe I do!! But the Ingines got two Casinos in this town so you would think it's a big town for where we are!
Going to role by Fastenal and Lowes to see if they have anything that will eat through grease! Pick-up a can or two of oven cleaner.
Alot of great idea's guy's, but some are good w/drawbacks. The high powered oven cleaner WILL take grease and paint from whatever it comes in contact with, including you if you don't wear protection:eek:. The best one imo is the steam cleaner. If it was me I would soak it down w/degreaser and let it soak 24 hrs. Then take on a trailer to the best hi pressured car wash in town and turn it on hot soap cycle. Should get most of it off. Good Luck and have a fun 4th.:)
Discussion Starter #18
I'd love for the paint to come off while I am at it! The last owner used what looks like a paint roller to apply paint to the engine compartment and frame rails. (Over lumps of dirt and all!!)
hook your pressure washer to your hot water heater. most water heaters have a port to screw on a water hose. just make sure the hose will hold up to hot water.
Jones, You can cut your brake clean costs by using a Sureshot sprayer and bulk brake clean. I buy 5 gal. pails of brake clean. The sureshot will hold over 250psi. and lots of brake clean or whatever else that needs to be sprayed. My sureshot is 6yrs. old, beat-up and working great with no leaks. I took it to a job yesterday. Also try methelene chloride on the paint. Get it Lowe's or sutch. Tres....
1 - 20 of 25 Posts
