1 - 6 of 6 Posts
· Registered
Rods
I think Dave Mclain has said no clearencing is necessary with aluminum rods and a 4.5 stroke in a stock block unless it is a D9TE. He also said A-460 Blocks need minor clearencing at the bottom of the bores.
· Registered
From my experience using an aluminum rod in a stock block is no problem at all. I've used the BME 396 forgings with a 4.500 stroke in several engines with no clearance issues at all.
I recommend aluminum rods over steel for very high rpm or horsepower applications. I feel that they are easier on everything else in the lower end of the engine.
1 - 6 of 6 Posts
