1 - 13 of 13 Posts
hey fellas :)
going to pick up a 460 engine this evening for free off craigslist, has low comp needs a quickie hone + ring job i bet.
anyways, its going to replace the twin turbocharged 302 in my fox.
looking at doing a large single blow through setup on the all stock 460 motor. figured id register on this site for when i need help with the swap :)
first question, will a c4 mount to the big block? or is it a c6 only type of deal
here is a video.
http://s64.photobucket.com/albums/h171/iitru45/?action=view&current=Picture006.flv
http://www.homemadeturbo.com/2006/Drags_4-28-06/Drags_4-28-06_rs.wmv
thanks
Johnny
BigBlockRanger said:
With the correct bell, yes.
excelent, this engine does not have a trans or anything attached to it, so i have the opportunity to get the correct parts the first time.
the bell that is needed for the c4 to bolt up which it is?
Like this one.
Probable not as rare as this guy claims tho.
Ebay ad
C4 bell and C4 trans
C6 bell does not come off voluntarily LOL
gimme a break and lets stop beating around the bush and come to a conclusion here.
is there a certain type of c4 say off a certain car that will only work up against the big block? like a c4 out of a car that had the 460?
C4 has a removable bell. C6 does not.
Get a C4 and put a BB bell on it. As for what cars to look in for a BBF to C4 bell I have no idea.
Might wanna start a new thread or do a search on this site. I'm sure there are more knowledgable tranny guys on here than me.
Mid to late 70's T-Birds, Cougars, and Ranchero's originally equipped with a 351M or 400 engine is your best bet for finding them.
Not all of these vehicles had the C4 trans, only a certain percentage did, you'll just have to search them out.
Also, a few big Ford vans had them as well.
77-78 t-birds and the like. Look for a 351M and a trans code W. You'll need a later model pan fill trans for the bell to bolt to - early model case fill C4s have bells that bolt to the pump. Or get a JW Ultrabell. You can read up on the differences between Ford trannys at the TCI site.
1 - 13 of 13 Posts
