1 - 20 of 36 Posts
Well,outside of the fact that the nitrous guys had a field day with me, (2nd, 5th, 6th runs) I got pretty fair results from the truck today after changing the frontend a couple weeks ago... I definitely need to get the rear suspension changed now... Simply just not quite enough weight transfer... I also had a problem keeping air in the rear tires and it took most of my runs to find someone that would let me use their air tank... The first run, somehow the nightshot button got switched on, but you can see my guages good... :lol: :lol: Ran a 7.31 @ 95mph with a 1.6 60' and it was only about 68*. Then it got up to 85* with no cloud cover and the guy next to me said they checked the track temp and it was at 120*. Couple that with too little air and my 60's went down the crapper. Finally found some air, added 2# and picked right back up... Let's just say I learned a little about tire pressure today :D :D :D
Enjoy... :wink:
http://www.youtube.com/watch?v=f1OXsdcQt2c 7.31 @ 95mph 1.6 60' @ 9-1/2 psi
http://www.youtube.com/watch?v=-dSFq7krQ6Y 7.42 @ 94mph 1.72 60' @ 9 psi
http://www.youtube.com/watch?v=_M75Sc2qrvY 7.44 @ 94mph 1.72 60' @ 9 psi
http://www.youtube.com/watch?v=QOpmP2VsrcI 7.47 @ 93mph 1.74 60'@ 8-1/2 psi
http://www.youtube.com/watch?v=tJDzOsNj9ug 7.52 @93mph 1.77 60' @ 8 psi
http://www.youtube.com/watch?v=0N58TrBuUDg 7.37 @ 94mph 1.63 60' @ 10 psi
Doug... 8)
S
Guest
#1 pound of air can change as much as 100 lbs of weigh in a oppsite corner.. That's why Randy told me to adjust my air pressure in 1/4 flats at a time.. I also found that even tho both tires had the same air pressure.. 1 tire was 88 inches while the other tire was 87 3/4.. Crazy
good show I'll look at the vids tomorrow!
Les
N
Guest
My inter net suck it looked like you got some wheel hope in the run with the yellow and gray car mite just be me good job i looked it up on map quest it is a 3 hour drive for me but im going to have to come out and watch you run. Good job DOUG.
Doug, I'll bet you were still the fastest white Ford truck there. 8) Get some of those problems sorted out and have fun. :lol:
Thanks Rob, If I can get that backend to stay squatted on launch just a few more feet, I think it'll pick up a bit still... I have the solution to the launch problems, but I'd need to employ a couple others I know would show up and help gat the rearend and suspension changed out, otherwise
I'll try and finish the season the way it is and then change out the rearend and suspension... That way I have 8 months to make sure it's right and not try to beat the next race...
Thanks Pat, I still havent done any real engine tuning yet, I'm still tryin' to get it to hook better first... How's yours coming along? Hope you get some more track time soon...
Thanks Jason, it was great talking to you the other night... It's always good to chat with other forum members... Hope you can make it over soon...
Doug... 8)
N
Guest
It was good talking to you to. Ill let you know soon when i can make it out that way and we will see what we can do on that truck to get it to hook better.
Thanks Nick... It runs great... I'v been analyzing the vids, and I'm noticing that my launch RPM sounds like it varies a good bit run to run... Think I need to check my 2-step and set it at 4500 and just pin the pedal :roll: All in all I'm still pretty happy with it. With the new front end, it drove alot more solid, with less steer going down the track...
Doug... 8)
Too bad we weren't a little closer, we could hook up and just get the rearend and suspension done and not have to worry about it 8)
Doug... 8)
N
Guest
ture ture what year is your turck and what trans are you running?
Im thinking about some thing what are you class rules about the chassis?
Did you see the post about the rules for the Rocky Mountain Door Slammers Quick 8 do you know the rules for that class off hand?
Discussion Starter #13
Truck's an 86 and running a C6. Converter flashes about 4500
I'll have to dig up the new rule sheet, they made a few changes, so I have to read it again.
I'll look into the rules for the Quick 8 also, I tried to get in the field once and found out I was 1-1/2 sec slow... Oh well, my time's comin' :twisted:
Doug... 8)
N
Guest
cool find out about the rules and let me know. What tire are you running and are you running motor mounts or a plate? ill go and look at you truck pics i mite be on to some thing here.
Discussion Starter #15
Right now I'm running a M/T ET Street 30x13.50x15. I'm running mounts, but they're solid...
Doug... 8)
80-86 were the same, then a front end facelift for 87-91 and another facelift 92-96. Basically same except for the grill and headlights.
I went back and looked at the vids a little closer and you are lifting the rear awefull bad. Do you have the battery in the back? Any weight you can transfer to the rear would be very helpfull. My truck just lays down in the back and flat hunkers down and goes. Probably helps that my front is pulling also though. 8) Put a transfer case back in and go all wheel drive down the track, like the diesel boys do. :shock: No more traction issues then. :wink:
Discussion Starter #19
Hey Rob, my rear bumper is 3" round tube... I drilled a 1/2" pipe hole in it and I'm gonna put some lead shot in it... Should hold a "few" bags ya think... I'm hoping maybe that'll help hold the rearend down...
I do have a battery in the back, but it's up closer to the cab... I was thinking also about running 2 batteries and mounting them at the back of the bed behind each wheel well...
Doug... 8)
N
Guest
Hey doug if you get a chance take a tape and tell me from axle cl to inside the cab about 2". I doing some thinking on some thing did you find out the rules for you class on the chassis yet.
1 - 20 of 36 Posts
