Hey guys the car is a 91 mustang coupe. the engine is a d9te factory shortblock flat top pistons .011 down in the hole. as for the heads i have a set of c8ve 429 heads with stock valves. i have started a mild port job and a bowl blend. the springs are good to about 600 lift. i was looking at a wide lobe cam around 580 600 lift i was trying to keep the car as mild as possible but i don't think it will happen with my goal of 10.99 on motor ! trans is a c6 2600 stall and i will be running 355 gears. as for limitations i have to run a torker 2 intake to fit under my stock hood ! any help with a combo would be great as i will be running the only bbf fox around !
