I have a '93 ford F250 460 4x4. It's had quite a bit of work done. It has less than 10k on a remanufactured 460 with stage 1 cam, and heavier valve springs. I put a banks power pack - so a banks cold air high flow air intake tubes and filter, headers, and full 3 inch banks exhaust with no cat- as well as a BBK duel 61mm throttle body and 1 inch spacer.
I need to upgrade my ignition system, but msd is in the works.
Engine backed with ZF-5 trans and a dana 80 1 ton single wheel axle off a f-350 with limited slip in the rear end. Has front leveling/overload springs rebuilt steering and 5k air bag helpers/overload springs in the back. Front is still the IFS dana 50 unfortunately. But I rebuilt it's compnants too, until I can put a solid axle swap.
What I need help with is my fuel and programming on the engine. For all the extras it doesn't feel like I'm getting all I can from it.
I was wondering about jet programmer/chip?
Also it still has stock old injectors and stock fuel regulator. Should I put a few more pound injectors in with a adjustable fuel regulator? Or just new stock lbs. Injectors?
It has way more lag than I would hope and it has been running a little rough. Any help is great. Thanks.
