for when I sell it in the future. I will be finished with my new motor sooner than I expected.
466 D1 block
Stock crank
oversized stock rods
Hyper pistons....flattop around 10 to 1 compression
D3 heads with rocker arm conversion. 2.20 intake 1.76 ex SS valves
exhaust side ported. Comp camps roller rockers 1.73 FMS - SVO valve covers
double roller timing chain
lunati cam .554 lift on int and ex 230 dur
weiand aluminum h2o pump (new)
stock type distributor
stock oil pan
no intake or carb
This motor pushed my car, at 3720lbs with me in it, to 7.90's at around 85mph. That was with a crappy torker 1 intake, mechanical fan, and a stock cast iron h2o pump. Shifting at 5900 rpm. Car has a 3.89 gear so I was running through the traps right at the shift from 2nd to 3rd. Motor has approximately 2000 miles on it with about 10 passes at the track. Starts right up and no smoke.
Any way, just trying to get an idea of what it is worth.
Thanks for any help in advance.
Tim
I just sold my engine of close to those exact specs except it had 10,000 miles on it and about the same passes for $2000.00 with intake/no carb.
Doug... 8)
