1 - 20 of 21 Posts
manifold
got a complete 73 ltd motor & trans 460/C6 sitting in the garage
where you located at ??
i am in Houston, tx
I've got a set. Both sides. Good condition. No cracks. They came off a 73 T-bird with D3 heads. I would sell them reasonable + actual shipping costs.
I'm out of town until Monday. When I return home I can dig them out of my storage building then just verify the condition and take a couple of pics.
David Cole
Thanks for the responses!
I'm in Des Moines - I'm going to get the exact part number I need on Monday - I'll post it here same day.
Thanks!
exh manifold
I was born in Ft Dodge, raised in Rutland. All my wifes people from W. Des Moines - Depending on how old you are you may know my relatives.
I have a 73 right side (passanger exhaust manifiold with the chimney sheetmetal piece just in case you are going origional) - Got an original air cleaner also - the exhaust manifold has a 2 inch spacer on the outlet end
I know this is a 73, but will confirm your casting part number if you wish - parts book part number wont be the same, need casting part number to verify. Although they may be the same, I would think that a T Bird and Linclon were different manifolds, after all they were different bodies with different exhaust systems, but may be wrong.
Let us know
Re: exh manifold
Let us know
I'll have the casting number in the AM - I post it back here right away.
Thanks for all the responses!
manifold in Des Moines
Post the casting #. I live 15 miles from Des Moines and may have one also.
Casting Number...
It's the passenger side manifold. I'll probably be interested in buying more than one.
Here goes:
D3VE 8430AB
Lemme know!
manifold
I looked around quickly tonite and it doesn't appear that I have one off. I have a 460 out of a 72 lincoln but can't find the casting #. Also have a 74? t-bird that needs to have the motor pulled but I can't see the # on that either.I will PM you my phone # and call me if you want to come look.I am only 30 minutes north of downtown Des Moines.
Andy.
I thought mine were from a 73 Tbird. I guess they were in a 74 based on the passenger side #'s.
The part #'s on mine:
passenger side D4VE 8430 A
drivers side C9VE 8431 A
If you think they might work let me know
David Cole
Discussion Starter #14
David Cole
Check you PM's.
1 - 20 of 21 Posts
