I have work for 4 days now on getting this new engine to fire and it is really starting to p#@s me off big time. I used to wire these duraspark's up now problem, but I have forgot how.
I put a pigtail off the duraspark box on the side with the 2 wires, one is white the other is red. Then I wired the red side straight to the positive side of battery. Then I hooked up the 4 wire lead on that goes from the duraspark box to the distributor and hooked up the coil. The red wire of the coil also goes straight to the positive side of the battery. I have the tach hooked up to the green side of coil.
It started like that, but the coil got warm to the touch. I let it run for about a minute and shut it down to clean up wires and keep them out of the pulleys. I can't get it to start back up now. WTF am I doing wrong.
