1 - 7 of 7 Posts
Fox body Mustang weight is 2880 race ready
Sportsman cage, ladder bars w/ Santuff rear coil overs w/ 12x100 springs
Front Santuff struts single adjust. w/ 14x175 springs
BBF (iron heads) c-6 trans 4500 conv. foot brake
29.5-10.5 slicks on 15 x 12 rims
Car launches straight lifts front about 1" then keeps front suspension up.
Problem is slow 60' and gets loose when track gets weak
Car runs low 10's in 1/4 60' 1.41 -1.46
The car was much faster with procharged windsor and glide (low 5's in 1/8)
Suspension was very stiff, I have been working on loosening it for a while.
Changes are front springs 150 to 175 and adj 3 1/2 full loose.
Rear 150 springs to 100 shock settings 5/7 to 9/18 drivers side and 10/15 pass side.
Ladder bar is set in middle hole of 3 (front) Bottom bar is 0*
Tire preasure 11 to 10
It doesn't seem to hit the tires hard enough?
Thanks for advise
Discussion Starter #2
suspension
With changes the 60'
old 1.39 to 1.49
Now 1.41 to 1.46
I was hoping to get better 60'
"Door slammers, The Chassis Book" by Dave Morgan.
http://www.summitracing.com/parts/CCA-158/
After you ingest the book, weigh the car and know what it wants you'll probably be getting rid of those ladder bars and installing a 4 link so you can actually hit the IC that you need. Hope that helps.
Rob
You keep on preaching this book Rob! I'm gonna have to pick it up before I get down and dirty with my setup! :D
Book
I have it. I keep rereading and this is were I am. Sorry I did not post the weights.
Front 1720
Rear 1180
59% nose heavy.
The struts are loose and the rear shocks are loosw on bottom and med. on top and changed springs, 12x150 to 12x100
I use pull off slicks, slicks from outlaw real street cars (low 5's 1/8) with 12 or so runs on them. The slicks have around 48 runs now.
Slicks
I found out how many runs I can get from these pull offs. I had 60 going into today, the temp was in the low 60's and I did not finish any passes. The car would launch ok (1.44/43 60') and then get loose and would have to shut it down around 330'.
Would it be worth the cost of new slicks, to go that route? I get the pull offs for $100 a set.
Another question:
On the suspension issue, will loosening the top(extension) adjustment on the rear shocks hit the tires harder?
And I am re-reading the book
1 - 7 of 7 Posts
