1 - 20 of 26 Posts
I am in the Detroit area. I prefer pickup but shipping can be arranged at buyers expense. Cash or paypel for payment. Money order will need to be a United States post office money order and will require clearing the bank before anything is shipped.
Ford 4x4 project I did a few years back and now Im just cleaning out the basement. Almost everything below is still in the original unopene
These are parts left over from a 1991 d packaging. You can call me directly to talk at 810-923-4137 or PM me. Calling me is the best way to get "dibs" as I may not be watching the website but once or twice a day due to work load. Items I mayu be interested for trading are Heads, RPM or torquer 2 manifold, 850 CFM or bigger 4150 style carb.
MSD distributer (8580) brand new with whatever gear they come stock with = $190 - PENDING
Crane steel distributer gear(52971-1) was told I needed it ofr my roller cam brand new = $60
Lunati cam (41605) with 14 lifters (cant find the other 2. This is used but very little. I have the cam card. 0.559IN/0.572EX, 237IN/247EX @ 0.050 duration = $110
Hughs torque converter (35-30HD) C6, 1.848 pilot hole, 10" 3000 Stall, brand new = $300
Transgo shift kit stage 1 and 2 (67-1&2) for C6. Brand new = $30
Power steering pump with plastic reservior. Fits 78 - 96 Bronco, F150 F250 F350 78 - 79 Cougar and LTD2 79 - 80 Thunderbird. Brand new = $75.00
Skyjacker front extended stainless brake lines for 4 and 6 inch lift for F250 and F350 (FBL 91) Brand new = $80
Skyjacker rear extended stainless brake lines for 4 and 6 inch lift for F250 and F350 (RBL 90) Brand new = $40
Vacuum reservoir with gauge (SUM-G1464)Brand new = $25
Brake master cylinder with tank from 1994 4x4 F350 dually. Has the large diameter bore piston = $35.00
Brake power booster (54-74400) 1990 - 1997 F250 and F350. Brand new = $50
Thank you
John
Do you have the part number inverted?
Hughs torque converter (30-35HD) C6, 1.848 pilot hole, 10" 3000 Stall, brand new = $300
That part number comes up as a C4 converter but the 35-30 comes up as you desribed. Wish it was the smaller pilot size.
Discussion Starter #15
Thanks Ranger. I did have it inverted. It is corrected in the listing now.
1 - 20 of 26 Posts
