holley black copy loosing psi and not pumping ?
its the pro comp 14 psi pump, same as the holley black. hey guys i have had this problem for a few weeks, i don't have the car drivable but just by starting it, it will hold 6 psi then a few minutes later it will loose psi and quit pumping ? the filter before the pump will be full and the filter before the carb will still have some fuel in it. the pump had a small leak so i put a new gasket on it and thought i had fixed it but it still has a small leak ? i am running out of options and need some fresh ideas. i do have another spring and relief valve i could put in it ! any ideas.....
