I've decided to buy a Holley XFlow for my 468 in my Bronco since I am having issues with vapor locking and will eliminate any future issues with the carb and angles while offroading.
I have run into an issue. I don't have the sufficient fuel pump pressure with the electric fuel pump (Carter 4600) I have now. Looks like I need 60 psi. I don't know what to exactly choose and I don't think I have an option to add an in tank fuel pump?
Any suggestions? Thanks!
Like you I can't get an in tank systen on mine due to tank shape and location so I went with Fitech Force Fuel, see link below....I'm also going to be using a Holley XFlow....That's one option. Another is to use an external fuel pump outside the tank, no more than two feet from the tank, many systems like this, Holley among others sells them. I chose not to go that rout due to the noise....you would have to add a return line and regulator to the system....many options and I'm sure others will have suggestions.
For me the Fitech seemed the best rout to try, good luck
Dan
