1 - 18 of 18 Posts
1
Guest
here is the first port on a set of heads that will go on my 545 motor..i am porting them my self..i have done a few small block but only one other set of BBF heads..which now i know a lot more about it..still nothing like a pro..hoping for 320-340 flow area...these are Dove-c heads..2.19-1.73 valves..i just finished a exhaust port ..the port to the right is stock on the exhaust and to the left on the intake side is the stock port
always good to see somebody having a go at doing their own work. just remember most factory 460 heads don't need too much work on the intake port, but quite a bit on the exhaust, concentrate on smoothness ? of flow out of the port and for the first few inches of the headers. 2' plus for your cubes l
Don't get to crazy on the floors. I don't know if you will get those flow #'s with the smaller intake valves. Mine maxed out around there with 2.25 in valves. 8)
getting there, valve size is really to small, go bigger, going by your pictures i can't tell if your exhaust ports have a [emissions/thermactor?] lump in them if you have remove them completeley. top of the exhaust port is more important than the bottom. use your gaskets to line up heads and manifolds the 950 carby is probably too small. HAVE FUN
1
Guest
these did not have the smog port in them..really think a 950 is to small?
In a word, YES. A 545 needs a 1050 dommy minimum, even with DOVE heads. Been there, done that. We ran a 1150 on our 514 and it liked it.
1
Guest
how well does the dommie work with a adapter ..my intake is a 4150 flange..
Your existing manifold can be modified for the Dominator flange. Cheaper than a new one. There are several people on the forum who can do it, if you can't do it yourself. Charlie Evans being one of them. I wouldn't run an adapter myself.
hi, yes the 950 is probably to small, leave the intake ports slightly rough to help fuel air mixing, the exhaust port can be as clean as you like, what kind of exhaust system are you running
1
Guest
Discussion Starter #12
2 inch tubes..3.5 collector..open headers..
1
Guest
Discussion Starter #14
i just finished both of the heads...these are going on my 460 motor in the car now..with my .680 roller..i want to get some racing in this year , adn i already bought a 4.5 stroke crank and h-beam rods, and have another block im working on for the 245, this motor will be my back up motor if it survives the beating i am fixing to hit it with...we will just see how much nitrous a lower end 460 can take..lol..i have my eyes on some p-51 heads , but i can not afford them till tax TIME..
1
Guest
Discussion Starter #16
speedtech460 said:
You will be very suprised how much that cheap bottom end will handle....stay away from detonation though, and dont spin it to the sky.
around 6000 rpm and 114 octane only with the juice
heads
Man they look good, i might get enough guts to port my own heads now, do you have any more pics you could post.
I think i read somewhere where dove heads could support 600-700hp if done right
1
Guest
Discussion Starter #18
Re: heads
thanks..i did get into the seat are more then i should..the machine shop almost had to put new seats in..eeee..but hey im still learning..if done 5 sets of heads now...this was the second 460 heads i had done the rest was 2 sets of small block ford heads and i set of BBC heads...each time i do a set i get better and learn a little more
1 - 18 of 18 Posts
