1 - 18 of 18 Posts
Ok, have finally got to get one. Never going to build the Titanic in the backyard, but might take on a whole chasis one day. Right now, sheet metal, motor mounts, etc...
What is a good, smart, buy?
N
Guest
I say get a tig welder but get one that has ac/dc . you can do ss alum ms cm a lot more then a mig can just my .02$ Jason
I bought a hobart handler 187 mig, it's ready for gas or can use flux core and will weld about anything you want.
Yes Tig MIGHT be a good thing but a mig is just easy to work with, and learn on and frankly you can weld anything with a mig you can with a tig unless your plannning on building a top fuel rig the tig really shouldn't be needed. JMHO
you need a high freq box and a pedal control to do aluminum.
Its much easier to do alum with a mig.
Any DC source can do tig, just reverse the leads.
You might find you need both Mig & Tig machines.
Any work with 'moly tubing or plate will require a Tig machine, as will Titanium. And the newer Tig machines that use "square-wave" technology are supposed to be so much better for welding aluminum.
But you wouldn't want to use a Tig on other shop projects like if you had to do some welding under the trailer filling a big gap in a cracked crossmember, or a broken weld. You would be there all day with a Tig, but a Mig would make short work of that job.
Like Dave said, you will find yourself needing both. I have a HTP 200 Mig, and Miller Syncrowave 180 Tig, and both are great machines. You might find this right up your alley. Lincoln has a new combo set that is really cool, both machines on the same cart a Power MIG 140C and the K2680-1 Precision TIG 225 sitting on top. They call it the One-For-All One Pak 8) .
http://www.mylincolnelectric.com/Catalog/equipmentdatasheet.aspx?p=50178#
I finally got a welder after all these years!!
A Miller 180 with autostart I love the thing. I haven't quite mastered welding sheetmetal but I really like it.
I fiqure if I need something tig welded I wouldn't know how to do it any way. So why buy the equipment just to have to take it to someone else that knows how to tig.
Welder
If you decide to go TIG, buy one with enough power to weld 1/2" aluminum plate or you'll be real sorry the first time you try to weld something like an intake manifold.
My little 185A machine will do it, but only if I heat the bajeezus out of the part in an oven before hand; it simply doesn't have enough power to do that kind of job without the preheat. It makes for ugly&weak welds in aluminum if you don't have enough power for the job at hand.
I've got a Lincoln 180 Mig... Works really well... I did my cage in my truck with it...
Doug... 8)
Re: Welder
Propane torch works wonders for this
blastertech70 said:
I got a miller 180 0n a bottle as well. I think for they guy that can't have both the mig has to be the most practicle to own first.
This was kinda what i was trying to say but put sooo much better then I did and frankly hte best advice so far IMHO
x2 on what byron said,
but it applies to a MIG as well. i have a lincoln mig, 110VAC and 135 amps of output and there are many times when it is not enough. Lincoln said it can handle 5/16", but it would take some prep work on the steel stock for it to push that much weld. i would say that 1/8" is the farthest i would push it. After that, its time for the arc welder.
And depending on your skill level you can do a lot of welding with an old arc(stick) welder. If your like me, welding on 4x4s where there is an endless sea of rust of and mud, sometimes its the only welder that will come close to working.
Re: Welder
I suppose if you had octopus arms and enough patience it'd work ok. I was welding bungs on an intake manifold, and needed to heat up a large area. I tried to repair a broken bellhousing (while bolted to an engine) using the torch method thinking I could create enough local heat to weld a crack. 3 map gas torches and 2 friends + my best effort with the tig yielded one incredibly ugly weld...so I guess it works. I think you need more skill than I possess to do that reliably and make pretty welds.
Re: Welder
I suppose if you had octopus arms and enough patience it'd work ok. I was welding bungs on an intake manifold, and needed to heat up a large area and was working solo. I once tried to repair a broken bellhousing (while bolted to an engine) using the torch method thinking I could create enough local heat to weld a crack. 3 map gas torches and 2 friends + my best effort with the tig yielded one incredibly ugly but functional weld...so I guess it works. Thank god for grinders. I think you need more skill than I possess to do that reliably and make pretty welds.
Oh, and my point...duh...after I gobbed up and made an ugly weld, he took it to a pro welder and the guy used a 500A tig machine, no pre-heating, and laid down a nice bead right over my ugly gob job in about 5 minutes, including the time it took to haul the equipment out under the lift. When it comes to welding heavy aluminum car parts, power is your friend.
Miller makes some piggyback style mig welders that you can hook up to your arc welder. I have one that has flux core wire in it and I am not afraid to weld almost anything nasty with it. I need to get a bottle conversion for it so I can weld with regular wire. Nice unit and most are relatively inexpensive if you already own the arc welder for the power source.
Miller 180 at the minimum. I have a 210 MIG & it is great. It is the biggest you can go before the real industrial machines like the 250 level. I'm not sure if it is the 210 still, but get the biggest one you can afford. Unless you LOVE your local shop, look to E-bay. BR welder got me mine for a $250 savings, shipped, No tax...
I have a Snap-on Mig that does everything I need it to do and then some. They have the capability for a spool gun for aluminum as well as a tig attachment. Only drawback is the tig is only for stainless and moly, wont do aluminum. I didn't realize that when I bought it so I made the snappy man GIVE me the spool gun for aluminum
1 - 18 of 18 Posts
