1 - 7 of 7 Posts
.030 over 460 , 4.5 inch stroker crank 545ci. 9.8to1 comp , pro comps with clean up work 2.19 in 1.71 ex valves , victor intake 850 dp carb , howards roller cam 296/304 .611/.594 , msd 6al 36 deg. crites 2 in headers full 3 in exhaust with h pipe. Any guesses. thanks.
The cam is a HR, 243/251 at .050", CL of 103*, needs 9.5 CR, 2400-5600 RPM. Called a "Big Daddy Rattler". One of those listen to my bad *** ride cams.
OP, did you buy the heads assembled or did you buy bare heads and have them professionally assembled?
Don't know why you wouldn't pump the comp to @10.8 to 1. Why cheap out on your heads? Just doesn't make since to me my friend.
I am interested in peoples thoughts as well.........
Never been a fan of those cams with less exhaust than intake lift ?? I would't use one . That cam you are going for now is a bit more like it :)
HP ... Hmmm I'll have a think on that :) Is that cam a roller or flat tappet ?
Its not all about the lift
1 - 7 of 7 Posts
