1 - 7 of 7 Posts
WHAT ARE THE DIFFERENTS
IN EACH ONE
AND
WITCH ONE IS THE BEST
AND
HOW DO YOU TELL THEM APART
AND IF YOU SE ADAPTORS
WITCH ONE IS BEST TO USE WITH C-460 HEADS
THANKS
GEORGE
intakes.
I am not really sure how many different ones they make but I have three different height intakes myself so they make at least three.
Re: intakes.
WELL ALL I KNOW IS WHAT I HAVE SEEN AND BEEN TOLD
THERE IS 1 CALLED THE HOMES
AND
THEN THE OLD STYLE
AND
THE NEW STYLE
THERE MAY BE MORE
I WOULD LIKE TO FIND OUT HOW MANAY THERE ARE
HOW EACH ONE IS DIFFERENT FROM THE OTHER
THE GOOD AND BAD POINT THAT EACH ON HAS
AND OUT OF ALL OF THEM
JUST BECAUSE THEY COME OUT WITH A NEWER STYLE DOES NOT MAKE IT BETTER THEN THE ONES IT REPLSACED
THANKS
GEORGE
George,
The original TFS manifold is the old style. It has very long runners and was nicknamed "the Holmes" by the Godfather, because of the long runners. It has been discontinued.
The new style TFS manifold is the short runner manifold and is what TFS is currently making.
The only person making adapters to put the A-460 intakes on C-460 heads is me, so there's not a lot of choices there.
Hope this helps,
And they are very nice adapters, indeed. I know, I have a set :)
THANK YOU
I WAS TALKING TO A PERSON
AND
HE SAD HE HAD THE OLD STYLE
BUT IT WAS NOT THE HOMES
BUT IN WAS NOT THE NEW STYLE EATHER
I ONLY NEW OF 2 STYLES
HE HOMES
AND
THE NEW STYLE TRICK FLOE
BETWEEN THE HOMES AND THE NEW STYLE
THANKS
GEORGE
Older Models
There was a 6" inch runner version of the tall runner manifold.
There were also some raw bases cast from Magnesium.
Some of those were long and short versions.
There were also some loose plenums Mag and Aluminum cast for weld in custom length manifolds by cutting the tall one down.
Then a loose runner/plenum kit was made as well.
1 - 7 of 7 Posts
