Looking to support around 750-800 NA horsepower when I get the BIG block together and then another 250ish on nitrous on top of that. I'm currently using a Mallory comp 140 electric pump and it has performed very well with my 550ish NA 408W, I was thinking about using it to supplement the nitrous but will need a pump to feed the rest. Suggestions? I currently run 8AN feed/return, will I need to go 10AN or larger for the main pump?
I'm going from the Mallory also to a a1000 -10 feed with -8 return with direct port nitrous and going to use my Mallory comp for nitrous with -8 feed and -6 return.
I've been looking at both the Magnafuel and Aeromotive pumps plus some others. I have good filters, so I may just go with the Magnafuel 500 part number 4401 in stead of the 4450 that has the filter built in. still open to all options.
