1 - 11 of 11 Posts
I think I might need to replace my Miller roller rockers, 1.8 ratio, with 1.7's, maybe anyone interested in doing a trade? I've been trying to get a cam for my pulling truck with a max .650 lift. And not much is available for the 1.8 ratio.
Doug did you try Shannons Engineering?
rockers
Might be interested in the millers if you want to part with them
Steve
Got a set of crane 1.7 but there the energizers
CompCams has 4 roller lobe profiles from 254° to 270° @.050" with .364" lobe lift listed in their master lobe list for "Race ONLY Cheater" Hydraulic or Mechanical "tight lash" use.
TEN degrees should be added to those @.050" numbers for comparable sizing because they are "tight lash" lobe profiles when used with a solid roller.
I can get you a "custom" cam ground if you are serious.
Randy: I tried calling you today. But no answer. I'll try calling you later. I called Comp. Cams the other day and the tech. could not find anything. Crane came up with a couple cams. The tech at Crane Cams said we shouldn't be running our 460's over 5000 RPM. They never were meant to do that. Hmmm???? :shock: :shock:
Banned
Crane is run by idiots
I run one of their cams way back broke retainer @9500rpm on the first run and called them, they said yes they have a great warranty :) and then explained if I started the engine the warranty was void ! :shock: so that brought up a question what good is a cam if you don't run it???
never again
Randy
Today was my "delivery" day so I was sometimes not near my telephone.
Oh Well ... !
1 - 11 of 11 Posts
