1 - 8 of 8 Posts
I WANT TO BUILD A STROKER NEED THE FOLLOWING PARTS
I WANT TO BUILD A 532 < or > 547 < or > 557 STROKER MOTOR
{{{{ THESE ARE THE PARTS THAT I HAVE ALL READY }}}}
NEW SET OF { 4.440 BORE } VENOLIA PISTONS & PINS {WILL SELL} IF I GET A SET OF 4.500 PISTONS
USED SET OF TRW L2443N .030 { WILL SELL } $300. or { TRADE } DOME 4.444 { or } 4.500 PISTONS
USED SET EAGLE 6.605 H BEAM RODS { WILL SELL} $300. { or } TRADE FOR 6.700 or 6.800 STEEL RODS WOULD LIKE I BEAM
NEW ALUM DRY SUMP PAN { NEED PUMP & TANK }
NEW M.S.D. CRANK TRIGGER DISTRIBUTOR & PLUG WIRES { NEED CRANK TRIGGER }
NEW MOROSO VACUME PUMP
NEW CRANE .850 ROLLER CAM { & } ROLLER LIFTERS
A460 HEADERS TO FIT MY CAR
B460 F.M.S. HEADS with 1.7 ROLLER ROCKRES , STUD GRIDL , F.M.S.VALVE COVERS { & } F.M.S. B460 INTAKE
{WILL SELL} IF I GET A SET A460 STYLE HEADS { or } WILL TRADE FOR A NICE OF A460 STYLE HEADS }
XXXXX THESE ARE THE PARTS I NEED XXXXX
A GOOD AFTER MARKT BLOCK
A GOOD STEEL { or } BILLIT CRANK { STD/STD IF POSABLE }
A GOOD STEEL { or } BILLET RODS { WOULD LIKE I BEAM RODS }
A 4.500 CRANK AND 6.700 RODS { or } A 4.300 CRANK AND A SET OF 6.800 RODS
A SET OF BIG DOME 4.500 BORE PISTONS FOR A460 HEADS
A- A460 TUNNAL RAM WITH {or } WITH OUT CARBS
A BIC SET OF MATCH DOMINATORS
A NICE SET OF A460 HEADS { & } SHAFT ROCKERS { & }SHEET METAL VALVE COVERS
CRANK TRIGER
WOULD LIKE TO BUY { or } TRADE FOR USED PARTS IF POSABLE
I ALSO NEED
2x4 TUNNAL RAM FOR FACTORY STYLE HEADS
GOOD SET OF FACTORY STYLE HEADS
A GOOD CRANK
THANKS
GEORGE
CRANK TRIGER
I ALSO NEED
A GOOD CRANK
THANKS
GEORGE
I have a set of A-429 heads with about 2 doz. passes on them since I freshened them up for $1500. They have studs, guide plates,Springs and 10 deg ret. SOme porting done to them on the ex side. I switched to P-51s. Springs are set up for a roller cam
Let me know Tore
Discussion Starter #7 (Edited)
OK
THANK
BUT FOR THIS MOTOR
I DO NOT WANT TO SPEND THAT MUCH
IT IS GOING TO BE A CHEAP MOTOR
TO USE WILE I GET THE PARTS
TO GETHER FOR A LIKE AHEADED 557
THANKS FOR TELLING ME ABOUT THEM
GOOD LUCK
AND
IF I HERE OF ANYONE THAT
WANTS THEM I WILL LET YOU KNOW
DO YOU HAVE ANY THING ELSE
TO SELL
1 - 8 of 8 Posts
