Next Topic >> Return to Index
IDT A-460 Eliminator Heads: Flow Test
January 1 2006 at 5:45 PM
No score for this post Charlie Evans (Login c.evans)
from IP address 64.12.117.9
Hey Guys,
In the middle of the three ring circus at the shop Friday, while we were dynoing another 598 CID Ford, I did a flow test for a customer from Tennessee that brought these heads in.
The heads were new and had been prepped by the folks at IDT. Their valve job and the chambers had all been hand worked and the bowls had "bowl blending". They were not ported, but had been port matched at the flange entry.
We flowed on a 4.625" bore @ 28" H2O. Intake valves were 2.425" in diameter and they averaged the following;
.100=79.5, .200=150, .300=231.3, .400=301, .500=358.6, .600=400.5, .700=433.5, .750=445.4, .800=457.3 cfm.
Hope you find this helpful,
Charlie
Author Reply
Jon Thee
(Login theemudracer)
152.163.101.9 was that a 45 degree seat or 52??
No score for this post January 1 2006, 5:49 PM
It would be interesting to know how many CC's the intake runner is.
very good info
Jon Thee
Charlie Evans
(Login c.evans)
64.12.117.9 Jon; 45* seat angle and 30* backcut around .075- .080" wide n/m
No score for this post January 1 2006, 5:52 PM
n/m
Jon Thee
152.163.101.9 nice numbers then!!!!!!n/m
No score for this post January 1 2006, 5:53 PM
n/m
Jon Thee
jeff hann
(Login cletus66)
205.188.117.68 Dang Charlie, Y'all have been busy.....Thanks for the info..........n/m
No score for this post January 1 2006, 10:35 PM
n./m
Charlie Evans
(Login c.evans)
64.12.117.9 Jon, They're 370 - 372 ccs
No score for this post January 2 2006, 11:11 PM
According to their literature if I remember correctly. The roof is raised .125" and their gasket is opened up to match. The intake port volume is a good bit larger than the TFS A-460 or EX 514 stuff. For comparison's sake, my CNC ported C-460, repeat C-460, intake volume is 381 - 383 ccs.
Hope this helps,
Charlie
Gary Blair
(Login GB3351)
12.191.228.53 What do you think about the volume of the IDT Charlie?
No score for this post January 3 2006, 3:07 AM
I don't quite understand a comparison to your C-460 volume.
Gary Blair
(Login GB3351)
12.191.228.53 Those are certainly good numbers. I have very little time
No score for this post January 2 2006, 12:24 AM
on the IDT head, however I would speculate that a full work up would yeild something like 470 CFM @ .800 with that size valve and 45* seats. With chamber work and 52* seats it is close to 490 CFM @ 1.00" lift. One other thing to note is the IDT head is .125 taller than the other "A" heads and I think this helps with a larger intake valve. You can run this chamber at 65 CC if needed. It's a real nice head.
Gary Blair
(Login GB3351)
12.191.228.53 Like Charlie said, those numbers are from a hand bowl blend.
No score for this post January 2 2006, 10:04 PM
IDT has several levels and options on porting including CNC finishing.
This message has been edited by GB3351 from IP address 12.191.228.53 on Jan 2, 2006 10:06 PM
B Howe
(Login BHoweDC)
216.221.96.201 Exhaust Flow #'s
No score for this post January 2 2006, 6:35 PM
Charlie,
Did you get a chance to do the exhaust also and how did they compare to the TFS A460 heads with comparable work into them?
1985 GT 466 TFS CJ heads. 6.48 @108.7 1/8 N/A, 9's @146 on the fogger.
Charlie Evans
(Login c.evans)
64.12.117.9 Yes; I Did,
No score for this post January 2 2006, 7:17 PM
just for shits and giggles. There is a problem in regards to the exhaust and we'll be contacting IDT about it this week and give them a chance to resolve it, which I'm sure they will. The numbers I got are not valid, so there's no use posting them.
However, I feel like the exhaust on these IDT heads is just as good as any other equally worked A-460 head, such as those from TFS or EX 514.
Hope this helps,
Charlie
Current Topic - IDT A-460 Eliminator Heads: Flow Test
idt heads
can any one tell me how to get a hold of jay or john that made idt head i have these heads and have some questions please
