1 - 6 of 6 Posts
I bought a universal ignition switch and solenoid and need to know how to wire them in. The switch has a battery, ignition, accesory and start. The solenoid has two posts and the starter switch input terminal. How do i wire it so the car will start when I turn the switch to start.
battery is the hot wire from the battery, acc is stuff like the radio, ignition is the dist or coil or ign box however your set up on your motor, start post goes to little start post on solenoid
My delima is this is going on a honda trx 125. It had a bad solenoid and bad starter switch. I put a solenoid and this switch on the atv. I have power going into my solenoid and switch. When i turn the key to the "on" position the ignition and accesory come on and when I go to "start" i have power coming out of my switch and into the solenoid, but I don't have power coming out of my solenoid. Any ideas
1 - 6 of 6 Posts
