1 - 3 of 3 Posts
i see a lot of vacuum ports on intake and carb.
i figure distributor to ?? what vac point.?
ok on power brake.
carb, 750 holley.? any? one on bottom..?
just block others?
ive been away from playing "cars" so scuse my dumb q s...!!
1 power brake large rear nipple rear carb baseplate.
2rear intake should have pipe threads for vacuum fitting for automatic trans /heater control vacuum cannister
3 fittings on carb metering block vacuum for TIMED spark advance,off at idle, on at engine speed
4 front carb base plate one-two fittings, use vacuum gauge to find full vacuum-manifold vacuum- hook this to single diaphragm distributer vacuum advance
ok,thanks. im not running yet so ill start by plugging all , then look at hooking up as you described.
im not familiar with the holley 750 i got used. now i can have a better look.
1 - 3 of 3 Posts
