1 - 7 of 7 Posts
Hello,
I'm reading-in about my EFI 460 project, and wonder something.
The stock 460 injector size is 24Lbs, and goes to somewhat 360 horses.
The next step is 30Lb, wich has a potential of 450 horse.
Now, this is at 90% duty cyle max.
Ther is naturally a sort of maximum injector size, else everybody would have fitted 100Lb injectors, right? Minimum size incurs idle and low rpm drivability.
As i intend to make a grunt low-rpm power torquey engine, this is important to me.
How do i determine my max. injector size?
I intend to idle at 400-500Rpm, and have a highway cruise rpm of about 1500Rpm max.
guessed max. overall RPM should be around, let say 5K rpm's.
So, range varying from 1-10.
Any info about the injector size?
I was thinking of 30 or 39Lb injectors, and in this case, are NOT a fan of bigger is better. I rather have it correct then too large...
Info highly appreciated, thank you :)
i ran 60 pounders in my 525 horse 521 that idled very nicely at 500-600 rpm with a small cam. at that point i still had lots of tuning room with the idle and the large injectors.
Also curious I have a 1993 f-350 4 door long bed the motor I’m dropping in it is a 460 cobra motor with cobra jet heads all roller rocker large cam pushing 650 hours power in addition to that I went to a bigger radiator dual electric fans and a full msd ignition system. Im trying to figure out what sized injectors to use and a high quality brand
1 - 7 of 7 Posts
