Installed Dove-c heads
1161 Views 3 Replies 3 Participants Last post by  rmcomprandy
Hi just installed dove-c heads on my 72 429 old heads were d2ve . Pistons circular dish with valve reliefs, Wondering what compression ratio would be and how advanced should i run this engine i was told from ford racing initial 20-25
If it's a stock 72 bottom end the CR will be somewhere in the 9.2(-ish) range and you should be running 10-12 initial and 32-34 total. Chances are you're going to have preignition problems unless you run premium or dial the timing back a little.
Brad
Ya im running premium with a little c12 seems to run ok just gotta get the timing right .
Regular driving with pump premium gasoline you'll want about 8 degrees, (that'll be 16 degrees from the total when shown on the crank dampner), in the distributor and probably around 34 - 36 total mechanical timing.
