1 - 3 of 3 Posts
WATER/METH INJECTION, Crank, Rods & Other Stuff
Chiseled Performance Air-Water Intercooler & Water-Tank
InterCooler--
3000HP - 4" Air Inlet/Outlet - 1 1/4" Water Inlet/Outlet
Perfect Condition - Used for 1 Season
Water-Tank--
14"x14"x9" - 7.5Gal - Rule 2000 In-Tank Pump
Insulated & Covered - Used 1 Season
$1400.00 -- SOLD
SuperCharger Store - Water/Methanol Injection System
2-Stage - Used on F2 ProCharger w/ Pump Gas - Made approx 1150hp
Stage 1 @ 7psi
Stage 2 @ 15psi
(Stage psi is adjustable)
Includes Pumps, Pressure Switches, 2ea 4" Stainless Collars w/ Spray Nozzles, Check Valves & 1/4" Push-Lock Fittings
$500.00 OBO
8ea-Comp Cams Hi-Tech Pushrods - 3/8" x 9.150 x .080 - $50.00 OBO
8ea Comp Cams Hi-Tech Pushrods - 3/8" x 9.650 x .080 - $50.00 OBO
8ea Comp Cams Hi-Tech Pushrods - 3/8" x 9.350 x .080 - $50.00 OBO
8ea Comp Cams Hi-Tech Pushrods - 3/8" x 9.750 x .080 - $50.00 OBO
15ea Comp Cams Endure-X Solid Roller Lifters - BBF
(1 broke, so I switched to Elite Series) -- $200.00 OBO
BBF 4.125 Stroke Crank - FoMoco Cast Crank - Offset Ground by Lunati
BBF Ford Mains .010 - 2.200 Rods - Magged and Checked OK
by Adnee Brown @ Performance Crankshaft - Made approx 1100HP
with Rods below - I Changed Combo (Crank/Rods) -- $450.00 OBO
Brooks Aluminum Rods - 6.695 x .990 Pin x 2.200 Journal
Used in NA 529 BBF - Probably 60-70 1/8mi Passes
Great Condition - Never Hurt (Changed Crank & Combo) - $200.00 OBO
Ford 9" Pinion Support - Small Pinion
Complete w/ Bearings, Seal & Spacer -- $50.00 OBO
Strange Chromoly Pinion Yoke - Small Pinion -- $70.00 OBO -- SOLD
Racepak Split Collar (4-Magnet) for Pinion Yoke
(Driveshaft Speed Sensor) -- $30.00 OBO
See Pics of everything here:
** PhotoBucket Link-- http://s1308.beta.photobucket.com/user/1Mavrich/library/Stuff For Sale
Located in Crestwood (Louisville), KY
[email protected]
Call or Text 502-817-6518
Thanks! -- Richard
1 - 3 of 3 Posts
