1 - 20 of 22 Posts
WE took this engine out of an AMBULANCE with 400,000 miles we found in the junk yard.
Was tore down,hot tanked,and checked for cracks,etc
Parts
I ported a set of dove heads Installed scj valves,ss. I'd say 3.5
Comp Cams solid lifter cam, not solid roller
MSD dist
Meling pump
PRO SYSTEMS 1150/1250 CFM carb 4500 dom
Victor 4500 Intake,ported
Installed big shot nos plate
reused the truck rods,new bolts
Reused the factory flat top pistons (was EFI) ,added little notch for PTV. ENGINE WAS STOCK 4.360 bore
Same crank ,3.850 stroke
Harland Sharps 1.73
truck pan,I welded in baffels
Hooker 429 460 foxbody headers
Ran alt,and factory waterpump
This engine was ran between 6800 and 7800 rpm
N.A.
RAN BEST 10.23 1/4 134
6.50 1/8
NOS
RAN BEST 8.97 1/4 152
5.78 1/8
@3065 LBS
that one was fun
was a solid flat, I will have to get the cam card out of the file and look, I wont get a chance till friday to do this,If you want you can call me then,thanks
BOSS 429;
I read and reread your post, and I found it amazing that by reworking stock parts for a performance build, and adding the basic (carb, intake,cam, valvetrain, and headers), you were able to turn those RPM's and make that kind of power. That performance shows respect to both your skills and the potential of the 460. Nice post.
Discussion Starter #12
I know it's an older post but what cam specs?
cam was a comp cam
solid lifter .649 .642 lift
270 276
108 center
this engine was built for a truck with efi,but at the last min it was stuck in the car,and had an intake change, this cam is not a NOS cam,but the combo worked very well with a bigshot nos plate under the 4500 dom (8896).
the iron cly heads(DOVE'S) WORKED very well,but that's what made all this work all the better. lots of welding,and grinding in and around the ports,and keep in mind this engine was in a good car that worked pretty good also
-Rich
Discussion Starter #14
how long did those rods last?
we never took them out, Not saying theres not better rods, just like Katies engine, it has truck rods, it will see a lot of nos next year, we will run it on nuts for a while first till she get use to it
katies build is on here also
This combination sounds pretty amazing. Any idea what those ported D0VEs flow CFM wise? I have a set I want to use and from what I can tell they will get me where I want to be with just a 466-472. I am also considering a 521 with some CNC ported D0VES, 2.25 intake valve and 1.76 exhaust...but the lower buck approach looks good too.
Great numbers man, very impressive for an ambulance engine.
Makes me wonder why I messed with small blocks for so long...
Discussion Starter #16
thanks for the kind words.
No idea on the cfm because no one wanted to take the time for me to flow them. We were in a rush to get the engine in the car.
We just tested Katies DOVE HEADED build last sat, ran well, I didn't do a crazy port work on the heads,in fact they aren't done the way id like them to be,BUT Katie got a little lazy as I was having her ruff them in for me because my time was better spent elsewhere.She didn't last long doing it,lol.In fact said shes going to pay somebody to do the next set lol.
Its a 466 solid flat,4500 carb,vic intake, 3.73 with a c6, I ran it first,then turned it over to her.
will post more up in the katies build thread in the next few days
How fast are you wanting to go? what car do you have?
Hello.
My car is an 82gt hatch. Mini tubbed, 325 drag radial car with coilovers, full cage.Reinforced subframe, tied front to back. Partial interior. Bullet proof 8.8 w/ 4:56 gear, spool etc. Fats and skinnies. 4 wheel disk. Car has gone 9.80's with previous engine/owner.
I ran less than stellar 1/4 miles with the mild 302 that was in it when i bought it. Yanked it a month ago and started collecting big block parts.
I would like to go High to mid 10's on motor. I have a nitrous system with a separate fuel system for the N20 I am also looking to install this winter...so with the gas I am hoping for a high 9...car has chassis for 10.0's but that can be improved.
I prefer to run the car on pump gas, but it can be set up for e85 if need be.
Discussion Starter #18
Hello.
sounds like a cool build,would like to see pics
1 - 20 of 22 Posts
