A few have asked me about this one,so here it is.
STOCK CRANK 3.850 STROKE
DOVE HEADS, PORTED, on a scale 1 to 5,say 3, 5 being what I call fully ported
Truck rods
comp solid roller,street roller cam
trw shelf piston,.060 w/dome
cast Iron factory intake.4150 dp holley carb, It needed a victor,and a 4500
cast Iron ehx manifolds, ehx system ran all the way back ,and over rearend to bumper
no h pipe
stock waterpump,and all stock pulleys
stock 60amp alt
truck oil pan,
meling pump hv
recurved duraspark dist
1.73 h/sharp rockers
Engine was run on dyno with alt hooked up ,charging,and beltdriven waterpump wo/fan
this cost some power ...................... /\
as DID THE STOCK CAST IRON INTAKE,& ehx manifolds< added 2-13-14
530 @ 6800 didint fall off till after 7100 at flywheel
Impressive!
Now thats an impressive build with EXH manifolds no less! What did the comp. ratio end up being and was it an 850CFM carb?
Great results! Can you post the duration at .050? Thanks for sharing.
950 PRO SYSTEMS, 11.7 or 12.2 TO 1, I think, been a while
